PMI
PMI - Product and manufacturing information. These are various dimensions and notes related to the specific 3D model elements.
PMI is imported with the model and stored within the model folder.
In the Geometrical model structure window , PMI is represented by the following objects:
Views
PMI nodes
Some PMI nodes have connections to 3D model objects.. When you select a PMI node, they are also highlighted.
When selecting the View model rotates in accordance with the coordinate system of View. If you change the visibility of View, the visibility of the associated PMI nodes also changes.
PMI import works for Step, JT, Prt(NX)
