Machine schema files
The CAM system uses machine schema to describe the kinematic model of the equipment (CNC machine, robot, etc.), its name, CNC system, using postprocessor file and some other settings. Typically, the scheme consists of a main xml file and several additional files that contain a 3D model for each of the machine nodes. They can have the extension .osd and .stl and be located either next to the xml file or in a subfolder. Machine schema files can also be placed inside encrypted zip-containers with the .stfc extension or inside the project .stcp file.
Use Machines library window to select desired machine schema file.
