Stepover
Step-over describes the toolpath section between work passes. For the plane operations it will be an X/Y axis step-over, and for the waterline – Z-axis. A step-over depending on the selected machining typemachining type can be performed either in contact with the model, or via the safe plane, or by the distance needed for the approach and / or retraction moves. Step-over cannot contain more than one approach and retraction element.
Tool trajectory parts
