The list of the basic CL-data commands
The CLDATA command that is generated by SprutCAM is listed in the table. The full list of the CLDATA commands see in the part 3 of this manual <Postprocessors generator>.
Command
Description
AXESBRAKE
Machine axes brakes control
CIRCLE
Motion by circle arc
COMMENT
Commentaries
COOLNT
The coolant Switch on/off
CUTCOM
The tool radius and tool length compensation
DELAY
Delay of time
EDMMOVE
EDM movement
EXTCYCLE
Extended cycle (drilling cycle, lathe cycle, milling cycle)
FEDRAT
Feedrate
FROM
Original point of the toolpath
GOHOME
Return to the home position
GOTO
The linear motion
INSERT
Insertion of a string to the NC code
INTERPOLATION
Different kind of Interpolation mode switch on/off
LOADTL
The tool loading
MULTIARC
Multiaxis circle movement
MULTIGOTO
Multi coordinate movement
OPSTOP
Optional stop of the NC code execution
ORIGIN
Coordinate system definition
PhysicGOTO
Physical machine axes movement
PLANE
The work plane (XY/YZ/ZX)
PPFUN
Postprocessor function
RAPID
Rapid feedrate
SELWORKPIECE
Active workpiece holder selection
SINGLETHREAD
Singlethread command
SPINDL
The spindle switch on/off
STOP
Stop of the NC code execution
TAKEOVER
Workpiece takeover into other spindle
WAIT
Waiting for synchronization point
