NC program files
NC programs are created by the postprocessor by conversion of the machining commands sequence into a sequence of commands for the CNC unit following the rules described in the postprocessor tuning file (*.sppx).
NC code is output by the postprocessor into a standard text file. The name can be defined in the postprocessor before generation. The extension of the output file is defined in the postprocessor tuning file (*.sppx). NC programs for different CNC controls can have different extensions therefore, different tuning files are used.
Transfer of the NC program from the computer, where SprutCAM X is installed, to the CNC unit can be performed by any available method.
