By two points
images/download/attachments/90486776/box13.jpg
The rectangle is built by specifying two diagonal points interactively, or by specifying the coordinates of the first point and the width/height of the rectangle in the inspector. You can rotate a rectangle only by changing the angle of rotation in the inspector.
Rectangle options in the <Property inspector> window:
images/download/attachments/90486776/box14.jpg
When defining a rectangle, you can use the help of guide lines. By default, guides are offered from the point being edited and the opposite point at angles of 0°, 45°, 90° and along a straight line passing through these points.
