Line
images/download/attachments/92864811/line1.jpg
<Line> is built on two points and has a point lying on the line and divides it in half. The line is constructed by specifying the coordinates of the end points of the line in the <Property inspector>. Also, using the mouse, you can move the line beyond its midpoint without changing its length and rotation angle. When the cursor captures the end points of a line, it is possible to dynamically change its length and rotation angle. If you press the [Shift] key, the line is moved without changing its length and angle.
Line parameters in the <Property inspector> window:
images/download/attachments/92864811/line2.jpg
When editing a line, all these parameters can be fixed by clicking the “lock” symbol in the inspector, or the appropriate icon on the line itself.
images/download/attachments/92864811/line3.jpg
When building and editing a line, it is possible to use the help of guide lines. By default, guides are offered at 0°, 45°, 90° and the angle at which the segment was previously created in edit mode.
In addition, you can create guides by hovering over a point on a previously created object:
images/download/attachments/92864811/line4.jpg
If you press the [Ctrl] key while drawing a line and hold the cursor over a previously created line, then perpendicular and parallel guides to this line, as well as a line that is a continuation, will be additionally proposed.
images/download/attachments/92864811/line5.jpg
images/download/attachments/92864811/line7.jpg
If an arc or circle was specified with the [Ctrl] key pressed, then a line tangent to the given arc/circle will be constructed. This applies to both the first and second points of the line.
images/download/attachments/92864811/line6.jpg
