Types of measuring cycles
There are several probing cycles with geometry:
There are also additional elements of working with cycles:
Cycles with geometry
All cycles with geometry have some common parameters:
  • <Orientation> - setting start orientation of tool in cycle. After adding cycle the orientation is set by <Auto>. You can switch on <Manual> and set orientation manually;
  • <Feed distance> - distance of approach to start position of cycle and return from last position of cycle;
  • <Stock> - additional shift of the target point along the target vector;
  • <Transition type> - setting an individual transition for current cycle. Transition values are described here;
  • <Compensate dimensions> - toolpath shift with tool compensation. This parameter is used in cycles where tool compensation is possible
You can set name of selected cycle in < Caption > field f or every cycles .
Notes: there is an additional <Cycle variant> parameter for turn probing operations. < Cycle variant > has two values: <Spindle on> and <Spindle off>. If < Spindle on > is selected then the spindle rotate before each approach to the touch point. Notes: there is no < Cycle variant > in surface probing. Hole, hole protected and boss probing has own < Cycle variant > .
Surface probing
Probing cycle using one surface surface.
images/download/attachments/90487745/image2022-3-18_16-21-19.png
Parameters of surface probing:
  • <Geometry item> - measured surface. You can edit position and vector of the point manually. You need to expand <Geometry item> and set values in the corresponding field s: < Target point >, < Target vector > ;
  • <Clearance> - distance between approach point and touch point.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Surface probing parameters" .
Hole probing
Probing cycle designed for measuring bore.
images/download/attachments/90487745/image2022-3-20_15-13-19.png
Parameters of hole probing:
  • <Geometry item> - measured surface of hole. Y ou can edit position, vector and center of the point manually. Y ou need to expand <Geometry item> and set values in the corresponding fields: <Target point>, <Target vector>, <Center point>;
  • <Top side> - determination of the top level from which we count the distance to the starting point of the cycle;
  • <Top clearance> - i f the parameter is checked then you set the distance from < Top side > to the start point of the cycle. If the parameter is unchecked then the start point is located at the < Center point > ;
  • <Depth> - distance from < Top side > to < Target point > in the direction of the hole;
  • <Diameter> - measuring hole diameter;
  • <Cycle variant> - the parameter has two values: <Rectangular> and <Angular>.
    • <Rectangular> mode creates 4 touch points with an angle of 90 degrees. Bypassing the touch points is implemented as follows: the first touch point is specified in the < Target point > , the second touch point is the opposite from the first . The third touch point is a point rotated 90 degrees from the first. The fourth point is the opposite of the third point. Notes: The spindle turns before approaching the third point in turn probing operations;
    • < Angular > has own parameters. <Start angle> allow to rotate < Target point > to specified angle. <Angular step> is distance between touch points. <Step count> allows you to set count of touch points. Bypassing the touch points is implemented as follows: the first touch point is specified in the < Target point > , then the points are bypassed along the specified < Angular step > . Notes: T he spindle turns before approaching each touch point.
images/download/attachments/90487745/image2022-3-20_17-33-45.png
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Hole probing parameters" .
Hole probing protected
Probing cycle designed to measure bore inside which there is an obstacle.
images/download/attachments/90487745/image2022-3-20_17-44-52.png
Parameters of hole probing protected:
  • <Geometry item> - measured surface of hole with obstacle . Y ou can edit position, vector and center of the point manually. Y ou need to expand <Geometry item> and set values in the corresponding fields: <Target point>, <Target vector>, <Center point>;
  • <Top clearance> - distance from < Top side > to the start point of the cycle ;
  • <Side clearance> - distance between approach point and touch point;
  • <Cycle variant> - exactly the same as cycle variant in hole probing.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Hole probing protected parameters" .
Boss probing
Probing cycle for measuring cylindrical bosses.
images/download/attachments/90487745/image2022-3-20_18-7-21.png
Parameters of boss probing are the same as in hole probing protected . T he only difference is that < Geometry item > is the boss, external surface.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Boss probing parameters" .
Internal rectangle probing
Probing cycle for measuring grooves and other recesses on four sides.
images/download/attachments/90487745/image2022-3-20_18-19-15.png
Parameters of internal rectangle probing:
  • <First side> - the first touch point. Y ou can edit position and vector of the point manually. Y ou need to expand <First side> and set values in the corresponding fields: <Target point 1>, <Target vector 1>;
  • <Second side> - the second touch point opposite the first point. Y ou can edit position and vector of the point manually. Y ou need to expand <Second side> and set values in the corresponding fields: <Target point 2>, <Target vector 2>;
  • <Third side> - the third touch point. Y ou can edit position and vector of the point manually. Y ou need to expand <Third side> and set values in the corresponding fields: <Target point 1>, <Target vector 1>;
  • <Fourth side> - the fourth touch point opposite the third point. Y ou can edit position and vector of the point manually. Y ou need to expand <Fourth side> and set values in the corresponding fields: <Target point 2>, <Target vector 2>;
  • <Top clearance> - i f the parameter is checked then you set the distance from < Top side > to the start point of the cycle. If the parameter is unchecked then the start point is located at the intersection of four points ;
  • <Width 1> - distance between < First side > and < Second side > ;
  • <Width 2> - distance between <Third side > and <Fourth side > ;
  • <Depth> - distance from < Top side > to points position.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Internal rectangle probing parameters" .
Internal rectangle probing protected
Probing cycle for measuring grooves and other recesses on four sides inside which there is an obstacle .
images/download/attachments/90487745/image2022-3-20_18-37-46.png
Parameters of this probing are the same as in internal rectangle probing. But it has two own parameters to avoid obstacles ( < Side clearance 1 > , < Side clearance 2 > ) and one parameter is changed ( < Top clearance > ) :
  • <Side clearance 1> - distance between approach point and < First side > and distance between approach point and < Second side >;
  • <Side clearance 2> - distance between approach point and <Third side > and distance between approach point and <Fourth side >;
  • <Top clearance> - distance from < Top side > to the start point of the cycle.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Internal rectangle probing protected parameters" .
External rectangle probing
Probing cycle for measuring projections or dimensions on four sides.
images/download/attachments/90487745/image2022-3-20_20-45-56.png
Parameters of extarnal rectangle probing are the same as in internal rectangle probing protected . T he only difference is that touch sides are external surfaces.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - External rectangle probing parameters" .
Web probing
Probing cycle for measuring projections or dimensions on two sides.
images/download/attachments/90487745/image2022-3-20_20-49-36.png
Parameters of web probing:
  • < Side clearance > - distance between approach point and < First side > and distance between approach point and < Second side >;
  • < Depth > - distance from < Top side > to points position;
  • <Width> - distance between < First side > and < Second side >.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Web probing parameters" .
Web probing (three points)
Probing cycle for measuring projections or dimensions on three sides. T he third side is between the first and second.
images/download/attachments/90487745/image2022-3-20_20-56-48.png
Parameters of web probing (three points):
  • <Left side> - the first touch point. Y ou can edit position and vector of the point manually. Y ou need to expand <Left side> and set values in the corresponding fields: <Target point 1>, <Target vector 1>;
  • <Right side> - the second touch point opposite the first point. Y ou can edit position and vector of the point manually. Y ou need to expand <Right side> and set values in the corresponding fields: <Target point 2>, <Target vector 2>;
  • <Middle side> - the third touch point between the first point and the second point. Y ou can edit position and vector of the point manually. Y ou need to expand <Middle side> and set values in the corresponding fields: <Target point 3>, <Target vector 3>;
  • <Middle clearance> - distance between approach point and <Middle side > ;
  • < Side clearance > - distance between approach point and <Left side > and distance between approach point and <Right side >;
  • < Depth > - distance from <Middle side > to the first and the second touch points;
  • <Width> - distance between <Left side > and <Right side >.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Web probing (three points) parameters" .
Groove probing
Probing cycle for measuring grooves and other recesses on two sides .
images/download/attachments/90487745/image2022-3-20_21-5-48.png
Parameters of groove probing:
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Groove probing parameters" .
Groove probing protected
Probing cycle for measuring grooves and other recesses on two sides inside which there is an obstacle .
images/download/attachments/90487745/image2022-3-20_21-10-46.png
Parameters of this probing are the same as in groove probing . But it has one own parameters to avoid obstacles ( < Side clearance > ) and one parameter is changed ( < Top clearance > ) :
  • <Side clearance> - distance between approach point and < First side > and distance between approach point and < Second side >;
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Groove probing protected parameters" .
Double wall internal corner probing
Probing cycle for measuring the internal angle between two surfaces.
images/download/attachments/90487745/image2022-3-20_21-17-9.png
Parameters of double wall internal corner:
  • <First wall> - the touch point of the first wall. Y ou can edit position and vector of the point manually. Y ou need to expand <First wall> and set values in the corresponding fields: <Target point>, <Target vector>;
  • <Second wall> - the touch point of the second wall. Y ou can edit position and vector of the point manually. Y ou need to expand <Second wall> and set values in the corresponding fields: <Target point>, <Target vector>;
  • <Clearance1> - distance between approach point and < First wall>;
  • <Clearance2> - distance between approach point and <Second wall>;
  • <First wall measure count> - count of touch points on the first wall. If count is more than one then you can set <Step>. < Step > is distance between touch points on the first wall;
  • <Second wall measure count> - count of touch points on the second wall. If count is more than one then you can set <Step>. < Step > is distance between touch points on the second wall.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Double wall internal corner probing parameters" .
Double wall external corner probing
Probing cycle for measuring the external angle between two surfaces.
images/download/attachments/90487745/image2022-3-20_21-40-0.png
Parameters of this probing are the same as in double wall internal corner. T he only difference is that touch walls are external surfaces.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Double wall external corner probing parameters" .
Triple wall internal corner probing
Probing cycle for measuring the internal angle between three surfaces.
images/download/attachments/90487745/image2022-3-20_22-18-32.png
Parameters of triple wall internal corner:
  • < Third wall > - the touch point of the third wall. Y ou can edit position and vector of the point manually. Y ou need to expand <Third wall> and set values in the corresponding fields: <Target point>, <Target vector>;
  • < Clearance1 > - distance between approach point and < First wall>;
  • < Clearance2 > - distance between approach point and <Second wall>;
  • < Clearance3 > - distance between approach point and <Third wall>.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Triple wall internal corner probing parameters" .
Triple wall external corner probing
Probing cycle for measuring the external angle between three surfaces.
images/download/attachments/90487745/image2022-3-20_22-24-17.png
Parameters of triple wall external corner:
  • < Top wall > - the touch point of the top wall. Y ou can edit position and vector of the point manually. Y ou need to expand <Top wall> and set values in the corresponding fields: <Target point>, <Target vector>;
  • < Top clearance > - distance between approach point and <Top wall>;
  • <Depth> - distance from <Top wall > to the touch point of the first and the second wall.
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Triple wall external corner probing parameters" .
Additional elements
NC action
The certain subroutine can be called after several successive measuring cycles. It performs additional actions or calculations based on the measurements just taken. These can be: calculation of average values, deviations, intersection points between several surfaces, recording these values in some rack variables.
It does not generate any movements. However, it can contain parameters that need to be either directly displayed in the NC using the Insert command or as a cycle with an array of numeric parameters. Through the mechanism of custom properties, you can add any parameters there. Based on these parameters in the postprocessor, it will be possible to form the necessary calls to subroutines and additional actions. Notes: In order to add custom properties, the <Show expert tools> mode must be enabled. < NC action > is located in < Probing cycle > - < Design a new cycle >.
images/download/attachments/90487745/image2022-3-20_22-54-19.png
images/download/attachments/90487745/image2022-3-20_22-42-52.png
A ccess codes for parameters in CLData are described in postprocessor documentation "Probing cycle <WProbing> - Additional parameters" .
Movement
Element for additional movement, for example to avoid obstacles. It is necessary to set the <Target point> through which an additional movement will be created.
images/download/attachments/90487745/image2022-3-20_22-51-14.png
Elements to group
Complex measuring cycles for the measurement of complex parts are usually performed not in isolation but in successive measurements connected with each other. For example, several measurements are performed and then the total result is calculated and written to the report under certain numbers which correspond to the hierarchy level of the measured element.
There are three types of group:
  • <Group> - general grouping;
  • <Component> - part to be measured;
  • <Feature> - individual element or surface currently being measured.
The level below goes directly measuring cycles. In the properties of the groups, you can set the number manually but by default it is automatically incremented relative to the previous value within the group of the corresponding type. The type and number of the group determines its name.
images/download/attachments/90487745/image2022-3-20_23-12-17.png
