Scripted operation
Script operation can have OnCreateMethod, ChangePropertyMethod and MakeWorkPathMethod methods defined.
  • OnCreateMethod is a sprut4 subprogram that is executed when operation is created.
  • ChangePropertyMethod is executed when operation property is changed.
  • MakeWorkPathMethod is executed when operation toolpath is calculated.
To create script operation use Create script operation.
images/download/attachments/84218971/image2020-4-17_15-31-14.png
First select parent operation. Any operation can be selected as parent. Parent operation defines basic properties of new script operation.
images/download/attachments/84218971/create_op.png
Input new operation parameters:
  • Caption or title - will be displayed in the technology tree. Operation caption is value of Comment node in operation xml-descriptor.
  • Name - this value will be new operations name in dialogs and menus for adding new operation to project. Name node in operation xml-descriptor.
  • Type - new operation type. Id attribute of operation xml-descriptor.
Use Operation properties panel to select what inherited properties will be visible in inspector.
When all parameters are set click Create template button to create xml-unit containing xml-descriptor of new operation and template Sprut4 project.
Also you can manually create operation descriptor xml-file and include it into SprutCAM X xml-configuration.
Brief Sprut4 description
Scripts IDE
