List of interpreter registers
INCT_RegisterList - interface that returns the interpreter function INCT_Interpreter.GetRegisters. The interface provides work with the list of interpreter registers.
Method
Method Description
Description of use
Get_Count
The function should return the number of interpreter registers to SprutCAM X.
No input parameters.
When forming a general list of registers, SprutCAM X calls the Get_Count function, gets the number of registers, and then sequentially, for each register, calls the Get_Item function.
Get_Item
By register number, the function should return the INCT_Register interface to SprutCAM X (see below).
Input parameter: Index (integer) - register number. Numbering starts with 0.
INCT_Register - interface, which is returned by the function interpreter INCT_RegisterList.Get_Item. The interface provides work with the parameters of the selected interpreter register.
Method
Method Description
Description of use
Get_Addr
The function should return the register address (string) to SprutCAM X.
The register address is used by SprutCAM X to find the register in the register list.
Get_Id
The function should return the register identifier in the machine kinematic diagram (string) to SprutCAM X.
Register identifier in the kinematic scheme of the machine, if applicable. Otherwise, the string is empty.
Get_Name
The function should return the register name (string) to SprutCAM X.
The unique name of the register. Used to uniquely identify the register in the list.
Get_Comment
The function should return a register comment (string) to SprutCAM X.
The function is called, but in the current version the value returned by the function is not used.
Get_Sign
The function should return a register character type (type TNCSign) to SprutCAM X.
sgnNoSign - without sign;
sgnMinus - only minus;
sgnPlusAndMinus - plus and minus.
Get_Point
The function should return register point type to SprutCAM X (the TNCPoint enumerated type).
pntNoPoint - without point;
pntPoint - point may be present, maybe not;
pntAlwaysPoint - the point is always present.
Get_BeforePoint
The function should return to SprutCAM X the number of characters to the register point (integer).
Get_AfterPoint
The function should return the number of characters after the register point (integer) to SprutCAM X.
Get_LeadingZeros
The function should return to SprutCAM X a sign of the presence of leading register zeros (boolean).
Get_TrailingZeroes
The function should return to SprutCAM X the sign of the presence of non-significant register zeros (logical).
Get_ValueAvail
The function should return a register type to SprutCAM X (the TNCValueAvailType enumerated type).
vatValue - the register consists of an address and a value;
vatOnlyAddr - the register consists only of the address;
vatBoth - a register can consist of both an address and an address and value.
Used in determining the register and its value.
Get_Values
The function should return a list of register values to SprutCAM X (interface INCT_RegisterValues).
INCT_RegisterValues.Get_Count - number of values
INCT_RegisterValues.Get_Value - index value (Index - integer)
The list of register values is used in determining the register and its value.
Get_Modal
The function should return the register modality (logical) to SprutCAM X.
Used when copying register values after interpreting the current frame. Modal registers are included in INCT_BlockExecArray only if the register value has changed in the current frame. Modeless always, if present in the current frame.
