Knife corner retraction
In every point of tool path the knife blade is rotated to be directed along the motion. The maximal rotation in one cut is limited by "max motion rotation". The maximal transition is also limited by "max motion length". (see picture below)
images/download/attachments/84218095/image2022-4-12_11-13-30.png
If the motion needs more rotation then few blocks will be generated to rotate the tool in the point.
If you want to retract the knife in the corner, then enable the option "corner retraction" and define the retraction value. The retraction will be performed if the corner is sharper than defined value "sharp corner".
images/download/attachments/84218095/CornerRetraction.jpg
KnifeCutting
