Requirements for IGES-file
The <IGES import> module has been developed based upon the specifications of <IGES> version 5.3. The system imports only IGES files in <ASCII> format. This means that IGES files, created in compressed ASCII-format or in binary format, will be evaluated by the system as incorrect. The system automatically defines the type of text file (DOS-type or UNIX-type, use different indications of the string end) and correctly loads both file types.
Importing objects from IGES files
