Advanced axes limits control
Option allows to avoid 2 kinds of problem in the 5-axis toolpath.
1. When it's possible, it excludes the overturn in the middle of work pass. Overturn is performed on the rapid motions.
2. It generates the smooth path in the singular zones. Singular zone is a machine position where the one of the machine axis can not be calculated. For example, if A-axis is equal zero, then C-axis can be any.
Option available in most 5-axes operations.
