Helical operation
images/download/attachments/84216679/HelicalOp.png images/download/attachments/84216679/HelicaMachining2.png
Parameters
Step
The vertical distance between any two adjacent complete helix turns.
Strategy
Use the Start From parameter to choose between the top-down and bottom-up machining. Use the milling type parameter to choose between climb and conventional milling.
Job zone
images/download/attachments/84216679/HelicaMachining_Top_Bot_2.png
The whole part is being machined. The Top and the Bottom levels of machining can be specified.
Types of machining operations
