Export of 3D Model
The function can be activated from main menu or <Save as> item in popup menu of geometrical model structure window. This action opens a file dialogue where user can to select one of supported format.
  • The <STL> format allows to deliver volumetric models as collection of flat triangles. Extension of the file is *.stl. The file is saved as text.
  • The <DXF> format basically used to deliver flat drafts and vectorial drawings. Volumetric models can be exported too, but has essential distinctions depending on version. In this moment is supported export of curves and points only. Extension of the file is *.dxf.
  • The <OpenGL stream data> is internal format of SprutCAM. Its used to save 3D models of single units of machines kinematic schemes. Extension of the file is *.osd.
Geometrical model preparation
