SpaceClaim™ toolbar & import addin
The toolbar allows you to export geometric data from SpaceClaim™ to SprutCAM X™.
The addin allows you to import SpaceClaim™ project files.
Supported file extensions: SLDASM, ASM, SLDPRT, PRT, SLDDRW, DRW, X_B, X_T, STP, STEP.
The required application (SpaceClaim™) must be installed on your computer for the correct work of this option.
Associativity
Default exchange between SpaceClaim™ and SprutCAM X™ is performed by Parasolid files (associativity is maintained). But this module is not included in the standard package of components for SpaceClaim™, therefore the possibility of manual shifting for exchange file was realized. In this case, the associativity would be lost, but export function stays available.
Expansion change instructions:
Go to the folder where the addin files (depends on the version, the path can vary, e.g.: "C:\ProgramData\SprutCAM Tech\SprutCAM X\Version 16\Addins\SpaceClaim");
Copy SpaceClaimTranslator.xml file and rename the copy as SpaceClaimTranslator_UserConfig.xml;
Move this file to the directory above (for example: "C:\ProgramData\SprutCAM Tech\SprutCAM X\Version 16\Addins\SpaceClaimTranslator_UserConfig.xml");
Open SpaceClaimTranslator_UserConfig.xml file and change the extension at line <OutputExtension>:
X_T - for Parasolid (only it maintains associativity);
STP - for STEP;
IGS - for IGES.
Save changes and Reinstall the toolbar in Addin Manager.
Deleting or renaming of SpaceClaimTranslator_UserConfig.xml file would lead to the default settings.
