KOMPAS™ toolbar & import addin
images/download/attachments/84215332/image2018-12-25_17-15-31.png
The toolbar allows you to export geometric data from Kompas™, Kompas LT™ or Kompas Home™ to SprutCAM X™.
There are two versions for target CAD system: x32 and x64.
In versions of Kompas V18+ does not work in a demo-mode.
images/download/attachments/84215332/image2018-12-25_17-15-11.png
The addin allows you to import project files Kompas™, Kompas LT™ or Kompas Home™.
Supported file extensions: A3D, M3D, CDW, FRW.
The required application (Kompas™, Kompas LT™ or Kompas Home™) must be installed on your computer for the correct work of this option.
Associativity
If operations that modify the whole body (such as moving, scaling, etc.) are used while model rebuilding in Kompas™, the associativity wouldn't work. These operations lead to a full reset of unique indexes, and they need to be re-assigned.
Addin's list
