Autodesk Inventor™ toolbar & import addin
images/download/attachments/84215277/InventorProFromAddinManager.png
The toolbar allows you to export geometric data from Autodesk Inventor Professional™ to SprutCAM X™.
images/download/attachments/84215277/image2022-3-30_11-50-5.png
The addin allows you to import Autodesk Inventor Professional™ project files.
Supported file extensions: IAM, IDW, IPT, IPN, IDE, PRT, ASM, SAT, STE, STEP, DWG, DXF, IGES, IGS.
The required application (Autodesk Inventor Professional™) must be installed on your computer for this option to work.
Autodesk Inventor Professional™2020 may have problems installing the toolbar:
If at startup the following window appears:
images/download/attachments/84215277/image2020-2-7_18-12-25.png
you must manually enable the toolbar in Autodesk Inventor Professional™2020. To do this, start the Add-in Manager in this window, or find the button on the ribbon panel:
images/download/attachments/84215277/image2020-2-7_18-15-14.png
In the window that opens, you need to find the SprutCAM X™ toolbar and set the parameters as shown in the following screenshot:
images/download/attachments/84215277/image2020-2-10_10-48-42.png
Then the SprutCAM X™ toolbar should appear on the ribbon panel.
Addin's list
