Importing objects from STEP files
<STEP> - Standard for Exchange of Product model data. The format of a <STEP>-File is defined in ISO 10303-21 (part 21 - geometric shape representation). <STEP> format allows the transfer of a multitude of different types of geometrical objects. This is why one can achieve data transfer between different systems with virtually no distortion. The <STEP> format is widely used, especially in areas where high data transmission accuracy is required due to very complex three-dimensional geometrical models.
Supports the following model types
  • wireframe;
  • surface;
  • solid bodies.
Schema files
  • CONFIG_CONTROL_DESIGN;
  • AUTOMOTIVE_DESIGN.
The standard extensions of files are .step; .stp.
Geometrical objects import
