System logs
There is a possibility to view a list of the main events that occurred in the application, starting from the moment of launch.
The events are displayed in a separate window, which can be called up from the Utilities/System logs menu.
images/download/attachments/84215000/image2022-3-22_16-26-10.png
Each event contains the time of occurrence and a description. If the description does not fit on one line, then at the beginning of the row the "Expand" button is displayed. Depending on the type of event, it can be drawn in different colors - red for errors, yellow for warnings and white for normal behavior.
This window can be useful, for example, in case of problems. Here you can track the details and try to understand the possible reasons.
