System settings
The window of system settings can be activated by pressing the
button. The default paths for the system files and languages are defined here.
The postprocessor adjustment files for various NC-system (*.sppx files) are loaded from the <Postprocessor files> directory. New postprocessor tuning files will be saved in this directory.
The SprutCAM projects are loaded as default from the <SprutCAM project> directory. The technological commands files (*.mcd), which are linked with opened project will be loaded from the corresponding paths, described in the project file.
The separate technological commands files (*.mcd) are loaded, as default, from the <MCD-files> directory.
Generated NC-programs are saved, as default, in the <NC-programs> directory.
To change program language it is necessary use <Languages> panel.
These paths may be edited manually or using dialogs, which can be activated by pressing
button.
In a system, there is a preconceived variable, which one may be used for definition of the conforming folders:
At determining actual names of folders during operation the indicated variable will be substituted by the conforming full path now of activation of a system or now of the last editing the system settings.
For load last opened *.SPPX file at activation of the generator of postprocessors there is a check box <Load last opened file at startup>.
