The separators of the mask elements
In general, the mask line consists of some elements. It is possible to inserts the spacebars between the elements. The spacebars has not influence on the NC-program line.
To control the spacebars between the words in the line it is possible to use the parameter <Spaces between commands>. If the parameter is checked then the spaces is added even if the separator is absent between the elements. For example:
Mask:
" G[2] X[100.101]Y[234.89] Z[45.67]"
NC code:
" G2 X100.101 Y243.890 Z045.670"
In the line, the space is added between the first and the second elements. The spaces quantity before the first between two and three, three and four is not changed.
If parameter <Spaces between commands> is off then all spaces between elements will be removed independently of it is quantity. For example:
Mask:
G_INTERP[INTERP] X[CLD.X] Y[CLD.Y] Z[CLD.Z]
NC code:
G1X-49.47Y-6.513Z.033
All spacebars is removed from the NC-program line.
