Modifiers
Some times, it is required to output the new register value independently if it is changed or not, and conversely to change the register value and do not output it to the current line. The modifiers <On> and <Off> is intend to do it.
The modifier is written in the square brackets after the value and comma.
Modifier <On>. If the modifier is written then the register value is output to the NC code in any case.
For example, lets the current register <G_PLANE> value is equal to 17:
  • Mask:
G_PLANE[17, On] X[XT] Y[YT]
  • NC code:
G17 X100.123 Y200.456
It is possible to out current value of register without the new value assign. To do it it is necessary to write <On> without value. For example:
  • Mask:
G_PLANE[On] X[CLD.X] Y[CLD.Y]
  • NC code:
Modifier <Off>. If the modifier is written then the new value is assigned to the register but the register is not output to the NC code. For example:
  • Mask:
G49G80M5M9 G_PLANE[17,Off]
  • NC code:
G49G80M5M9
It is possible to use modifier <Off> without value. It is needed to exclude the out of the current register value to the NC code without the assigning of a new value.
Mask structure
