Milling types
In the system it is possible to generate tool movement trajectories of climb or conventional milling.
If the milling type is not important, then it is advised to set the mode without considering the milling type. This mode allows considerable reduction of non-cut passes and consequently decreases the machining time.
Milling type can be defined in the <Strategy> page.
