<Additional> tab
Use <Additional> page to setup SprutCAM events logging and SprutCAM updating settings.
Logs are useful when you encounter issues which are difficult to explain in words or which occur only when a specific consequence of actions is executed.
To enable updates checking switch on <Check for updates> option.
Switch on <Semi-automatic update> to start downloading updates right after click the "Updates found" notification.
To enable logging check the <Use logs> option.
Enter the folder path in which you want SprutCAM to save the logs into the <Log folder> field.
If you want SprutCAM to send error reports automatically check the <Send report after incorrectly application finish> option.
The <Check Program Compatibility Assistance items> option is used to exclude the SprutCAM from Program Compatibility Assistant.
To log the interaction of SprutCAM with the interpreter in G-code based simulation mode and G-code based milling operation use the option <Use log interaction with the interpreter>.
The <External STCX-editor> panel is affects "NC-program generation" window and allows you to select an external editor to edit the NC-program.
The <Show expert tools> option is used to make some tools visible, that will be useful to expert users.
The <Show smart hints> option enables/disables the visibility of smart hints.
