Operations matrix
     Configurations Operations  |
     Express  |
     Wire EDM  |
     Lathe  |
     Cutting  |
     2.5 Mill  |
     3x Mill Entry  |
     3x Mill Advanced  |
     Rotary  |
     5x Mill  |
     Operations for 2/2.5D milling  |
     2D contouring  |
     Engraving  |
     2.5D pocketing  |
     2.5D wall machining  |
     2.5D cover machining  |
     2.5D chamfer machining  |
     Pocketing  |
     Hole machining  |
     Operations for 3D milling + indexed rotary axes  |
     3D contouring  |
     Flat land machining  |
     Waterline roughing operation  |
     Plane roughing operation  |
     Waterline finishing operation  |
     Plane finishing operation  |
     Optimized plane operation  |
     Complex operation (waterline-plane)  |
     Morph operation  |
     3D Helical operation  |
     Scallop operation  |
     Face milling  |
     FBM  |
     Operations for 4-axes and 5-axes milling  |
     4D contouring operation  |
     4D surfacing  |
     Rotary waterline  |
     Rotary roughing  |
     Rotary finishing  |
     Morph 4D  |
     5D contouring  |
     5D surfacing  |
     5D by meshes  |
     Rest machining  |
     Corners cleanup  |
     Pencil  |
     Chamfering  |
     Lathe  |
     OD roughing, ID roughing operations  |
     OD finishing, ID finishing operations  |
     Lathe facing operation  |
     Lathe hole machining operation  |
     Lathe part-off operation  |
     OD grooving, ID grooving, Face grooving operations  |
     OD threading, ID threading, Profile threading operations  |
     Cut machining  |
     Jet cutting  |
     Jet cutting 4D  |
     Jet cutting 5D  |
     Wire EDM  |
     2D contouring  |
     4D contouring  |
     Cladding  |
     Area cladding  |
     Curve cladding  |
     Cladding 3D  |
     Cladding 5D  |
     Welding  |
     Welding  |
     Knife cutting  |
     Knife cutting 2D  |
     Knife cutting 6D  |
     Disc tool  |
     Disc roughing  |
     Disc cutting 2D  |
     Disc cutting 6D  |
     Auxiliary operations  |
     Group  |
     Auxiliary  |
     G-code based, G-code based lathe  |
✓ — available
○ — option (need additional license)
