This operation is available as option of SprutCAM.
It implements the functionality of automatic weld seam geometry calculation without reference to the particular type of welding equipment, ie it does not generate the specific commands to the laser, electric arc, gas burners, ultrasonic emitters etc. Setting up of operation to work with specific type of equipment can be made by writing in the postprocessor appropriate commands to control the equipment, or, if this is not enough, by the addition of a special operation on the basis of the Welding 5D operation, adapted to control specific equipment.
Note: option must me licensed separately.
