Adaptive MW
SprutCAM's module for efficient roughing.
Adaptive roughing strategy ensures that the high speed cutting conditions remain almost constant by which offers great improvements compared to conventional constant offset roughing strategies. The strategy avoids full-width cuts by constantly measuring the engagement volume of the tool with material and gradually removing material off the remaining stock. It guarantees stable load on the tool, which allows an increased material removal rate at higher feed rates and reduces the overall machining time.
Advantages:
Reduction in machining cycle time
Extended tool life
Features:
Supports 2-axis and 3-axis models
No full width cuts
Consistent engagement with material
Trochoidal like passes to progressively cut corners
Supports intermediate slices & rest roughing
Multi-core CPU support for faster calculation times
This module is available at operations:
     "Roughing waterline"  |
 Inspector's parameters for Adaptive roughing module
     "5ax multi surface"  |
This module is available for SprutCAM's configurations.
Remark: need additional license for module "Adaptive MW". Or included to "5D MW" license .
