Operation with scripted events
Operation with scripted toolpath commands is created from a regular SprutCAM operation using Scripts Editor.
On Scripts Editor window's Left Panel select Events Handlers tab. Select an item in Objects tree and the Events tree will display available events for that object. Double-clicking on event will create a code template for method that will be executed when SprutCAM processes that object in toolpath. See Scripts IDE for more information.
