Interpreter settings file
The settings file has SNCI (Sprut Numerical Control Interpreter) extension and XML format. The description of its elements is given below. Required parameters are marked with a sign in the corresponding column.
Description of the SNCI file elements
Element name
Field format
Description
Required
NCInterpreter
Tag
Root element
2
CNCSystem
String
Name of stand / machine
3
MachineType
String
Machine type. Variations:
  • Lathe
  • Mill
  • TurnMill
  • Robots
  • WireEDM
4
UseGeomCLData
Logical
Specifies the use of the interface of the tool motion path construction in geometric axes (Logical).
True - is that the INCT_GeomCLData interface is passed to the interpreter to form the trajectory of the tool movement from SprutCAM.
False - the INCT_CLData interface is passed to the interpreter to form the trajectory of the tool movement from SprutCAM.
The default value is False.
5
Date
Date
Interpreter date in dd.mm.yyyy format
Authors
String
Developer(-s)
7
Company
String
Company
8
Description
String
Description
9
Version
Number
Version
10
ID
GUID
Interpreter ID (must be unique)
11
LibraryID
GUID
Software library ID (must be unique)
12
LibraryFileName_Net
String
Link to the software library for the .NET platform
13
NetNamespaceClass
String
Namespace and name of the class that implements the interpreter (if the LibraryFileName_Net field is filled)
14
LibraryFileName_x32
String
Link to x32 software library (used if the LibraryFileName_Net field is not filled)
15
LibraryFileName_x64
String
Link to x64 software library (used if the LibraryFileName_Net field is not filled)
16
ParentID
GUID
Parent Interpreter ID (ID field in parent SNCI file)
17
ParentFileName
String
Link to the parent interpreter settings file (SNCI file)
18
FileExtension
String
File extension with NC code
19
Registers
Tag
List of interpreter registers
* - required field;
** - the LibraryFileName_Net field or both fields LibraryFileName_x32, LibraryFileName_x64 must be filled;
*** - the field must be filled in if the LibraryFileName_Net field is filled.
Description of each item from the register list (Registers):
Element name
Field format
Description
Address
String
Register address
2
Name
String
Register name
3
Id
String
Register ID
4
Comment
String
Comment
5
AddrOnly
String
Value options:
  • aoValue - The NC word consists only of the address and meaning
  • aoAddr - The NC word consists only of the address
  • aoBoth - The NC word that can consist of both an address and an address and value.
Sign
Integer
Value sign:
  • 0 - without sign
  • 1 - only '-'
  • 2 - '+' and '-'
7
NumeralsBeforePoint.Count
Integer
Characters to the point
8
NumeralsBeforePoint.Zeros
Boolean
Presence of leading zeros
9
DecimalPoint
Integer
Decimal point:
  • 0 - without '.'
  • 1 - '.'
  • 2 - always '.'
10
NumeralsAfterPoint.Count
Integer
Characters after the point
11
NumeralsAfterPoint.Zeros
Boolean
Trailing zeros
12
Scale
Number
Scale
13
Modal
Boolean
Sign of register modality
14
ModalGroupList
List of values
The list of values that can get the register
The Version field is reserved for future use.
Important elements of the interpreter's settings file are: its own identifier (ID), identifier (LibraryID) and link to .NET / x32 / x64 version software library files (LibraryFileName_*), identifier (ParentID) and link to parent interpreter (ParentFileName). The identifiers of the settings file and the program library must be unique (see the GUID article: Globally Unique Identifier).
The LibraryFileName_* field should point to files, with a program library, relative to the directory where the SNCI file is located. It is recommended to place the file with the program library in the directory with the SNCI file.
There are two options for connecting the program library to SprutCAM:
  1. The software library is designed for the .NET platform (for example, in C #).
    In this case, you must fill in the LibraryFileName_Net and NetNamespaceClass fields, where:
    LibraryFileName_Net - link to the program library.
    NetNamespaceClass is a namespace and class that implements the interface of interaction with the interpreter. Format: Namespace.Class, for example: sample.Interpreter.
  2. The program library is native (written in Delphi, C ++, etc.)
    In this case, the LibraryFileName_x32 and LibraryFileName_x64 fields should be filled in (reference to the x32 / x64 program library, respectively).Versions of the x32 / x64 software library should be called by the same name, but with different prefixes. For example: Sample_x32.dll / Sample_x64.dll or Sample_Win32.dll / Sample_Win64.dll. Where "Sample" is the name of the program library.
If the interpreter is not the inheritor of another interpreter, then the parent fields are filled with empty values:
<ParentID>{00000000-0000-0000-0000-000000000000}</ParentID>
<ParentFileName/>
The FileExtension field is reserved for future use.
In the Registers field is a list of registers for automatic selection of words from the NC code. The order of transmission of the control program frame is described in the following article. The interpreter configuration file may be not complete list of registers, it will be received by the interpreter program library, however tag <Registers/> must be attend.
The use of the interpreter settings file is given in the G-code based program interpretation section.
An example of the interpreter settings file for the native library (x32/x64):
<?xml version="1.0" encoding="UTF-8" ?>
<NCInterpreter>
<CNCSystem>Sample CNC (mill)</CNCSystem>
<MachineType>Mill</MachineType>
<Date>01.01.2019</Date>
<Authors>Ivan Danko</Authors>
<Company>SPRUT Technology</Company>
<Description>Interpreter for Sample CNC</Description>
<Version>1</Version>
<ID>{79B1410C-67D5-42B6-867B-A3BF30AB3D8A}</ID>
<LibraryID>{80F754D9-EE7B-47CF-A802-A9424D9F6749}</LibraryID>
<LibraryFileName_x32>Sample_x32.dll</LibraryFileName_x32>
<LibraryFileName_x64>Sample_x64.dll</LibraryFileName_x64>
<ParentFileName/>
<FileExtension>*.cnc</FileExtension>
<Registers/></NCInterpreter>
download example Sample.snci.
