Fixtures
Creating a new fixtures
To create equipment, you should select an existing template or create your own version of equipment using the "New node" button.
images/download/attachments/79701057/image2021-4-29_11-11-5.png
The newly created template and nodes are seen in the equipment tree.
images/download/attachments/79701057/image2021-4-29_11-34-22.png
Geometry
To add geometry, select an equipment node and click one of the geometry buttons.
images/download/attachments/79701057/image2021-4-29_11-43-3.png
Configuring node parameters
Configuring node parameters are set in the Properties window that can be opened by double-clicking on a tree node or clicking the properties button on the main panel of the page.
images/download/attachments/79701057/image2021-4-29_14-11-14.png
The main parameters of the node, such as the maximum (minimum) position, direction and rotation axis, can also be specified using visual objects.
images/download/attachments/79701057/image2021-4-29_14-24-36.png
Component setting
The position of the component is adjusted using a visual object.
images/download/attachments/79701057/image2021-4-29_14-45-10.png
It can be invoked by double-clicking on the node or by one-click in component edit mode.images/download/thumbnails/79701057/image2021-4-29_14-47-33.png .
When you right-click on a visual object, images/download/thumbnails/79701057/image2021-4-29_14-53-34.png panel is showed up. It allows you to copy and delete components.
Snapping a coordinate systems
If your equipment is defined in a machine unit, then it is linked to a specific setup and moves with the machine.
images/download/attachments/79701057/image2021-4-29_14-59-16.png
images/download/attachments/79701057/image2021-4-29_14-59-29.png
If it is in the operation node, then it is linked to the current setup and can be moved both with the machine tool and with the part.
images/download/attachments/79701057/image2021-4-29_15-52-14.png
Saving and loading
Equipment can be saved by right-clicking in the Component Tree or by clicking the Save button.
images/download/attachments/79701057/image2021-4-29_15-58-45.png
Hardware can be loaded by right-clicking in the Component Tree or in the drop-down panel of the Load button.
images/download/attachments/79701057/image2021-4-29_11-13-52.png
