IronCAD™ toolbar
The toolbar allows you to export geometric data from IronCAD™ to SprutCAM™.
Once installed, the toolbar may not appear in IronCAD™. Then you need to press
in the dialog box to activate it:
Supported file extensions: ICS, IC3D, ICSW, ICD, EXB.
The required application (IronCAD™) must be installed on your computer for this option to work.
